With pressure in tank test for leak at the check valve. Follow the discharge line from the pump to the tank. There you will find the checkvalve (usually brass valve). If the check valve leaks the compressor will be under load when motor tries to start and will probably trip breaker. Look for reset button (red button )on the compressor motor and push-in to reset. With pressure in tank the motor /pump should turn freely by hand. If checkvalve good and unit turns freely, test capacitor for proper valve. It should test to within 95% of printed uf/mfd. Good holidays
Hi - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
