Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
Posted on Jul 01, 2008
Squealing noise My Bosch SHU4326UC dishwasher has just started making a squealing noise during the normal cycle. Seems to happen at least 3 times throughout the cycle.
  • Anonymous Aug 28, 2008
    It was squealing, not it won't turn on. I think the bearings are ceased.
  • wmbond Jan 07, 2009
    I have a similar problem ... unit squeals at various intervals however, the dishwasher is only a year old.  I would expect a longer life out of major mechanical parts such as motors, pumps, etc.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3273
Points
Had same squealing problem.... had machine checked over. NOTHING WRONG.
Repair people ran it a few times with just water and no squealing at all. they also ran it with detergent capsule [Fairy] No squealing. Have got it back to monitor it. Used Fairy capsules for a few washes and no problems. As soon as I used the Waitrose Essential concentrated dishwasher liquid, the squeak was back with a vengeance.
The moral of my story is TRY NOT USING LIQUID DISHWASHER DETERGENT
Anonymous
Level 1:
  • Posted on Sep 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3273
Points
The pump motor is beginning to seize up. You may be able to take the dishwasher apart and lubricate the bearings and keep it going for a while, but at some point you will likely have to replace the pump motor assembly.
M Coupland
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 20, 2015
M Coupland
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6756
Points
7
I confirm what Dot Milton found: switching from liquid detergent to powder fixed the problem for me.
Anonymous
Level 1:
  • Posted on Aug 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3273
Points
Sorry, haven't got a solution but I have the same problem with my bosch dishwasher too.
  • Anonymous Jul 14, 2014
    My dishwasher died after a year of the squealing!
    i think Selwyn Schultz is right suggesting the pump motor is seizing up.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Frigidaire dishwasher model number FDB4050LHS1 making a loud squealing noise
Usually this is the drying time of the cycle. I would have a professional look into the blower assembly and heating elements of the unit.
Aug 25, 2012 • Dishwashers
1helpful
Kenmore 587-1519 dishwasher 5 years old just started making a squealing noise during certain times on any wash cycle. Noise is coming from under the tub.
Sounds like something is stuck in the pump. Your pump propeller may be going out causing strain on the windings of the pump. If you have anymore questions please comment me back.
11helpful
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
MAKING SQUEALING NOISE
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsj
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Dishwasher makes a whineing or squealing noise during wash cycle. No noise during filling and draining.
Motor has something in it ( dirt,dust etc..)If it gets worse replace the motor.
1helpful
Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Mar 28, 2008 • Dishwashers
2answers
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
9helpful
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
