Check the fuel filter and the fuel strainer. The strainer is located on the right side of the heater at the bottom. It is on the side of the fuel sump with 2 screws holding the cover on. Turn off the valve at the oil barrel before removing the strainer and have some rags ready to catch the fuel that will come out. You may also have an air bubble in the line. Use the small screw on top of the filter to vent the filter. You can also place a bowl under the line where it connects to the back of the heater and loosen the line so you can get the kerosene flow started. Hope this helps.
