SOURCE: how can I boost the signal of my Verizon MiFi 2200
You cannot connect a router to your Mifi as it does not LAn port. You can use wireless access point to amplify your wireless signal
SOURCE: I purchased a mifi 2372
Samething with me. I have a mifi and it can connect to the playstation but cant sign in. It says it a DNS error. Which means one of your DNS numbers have blacked out and it can be fixed by getting knew dns numbers.
SOURCE: I just purchased a verizon
Welcome to Fixya. The Address is 192.168.1.1 and the password is admin. I provided a link on how to setup the Verizon Novatel MiFi 2000 so that it will be able answer your question.
If you have questions please let me know. Thanks for using Fixya.
SOURCE: My Verizon Wireless MiFi 2200 CB93 is suposed to
First reset your MiFi back to factory settings .Download this manual > http://cache.vzw.com/multimedia/mim/mifi_2200/mifi2200.pdf and go to page #63 for instructions.
Next update the firmware >>click HERE and follow the instructions.
SOURCE: My verizon MiFi 2200 is
OK this problem has to do with the drivers and the USB port, it is the HP driver and the Novatel conflicting this problem is a very common problem?
All one can really do is re-install, after first un-installing the old software, try that and it may help, although, i haven't really seen a conclusive fix?
You may have to also un-install the HP, software too, then get it all working, and try again. Also make sure you have the absolute latest drivers, for the Modem.
Below is a list of error codes etc for your unit.
http://www.chicagotech.net/raserrors.htm#Error%20633%20Modem%20Is%20Already%20in%20Use
