Dell Dimension E520 PC Desktop Logo
Posted on Dec 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer will not show any video, Power lights on front, power lights on mother board, series of 5 long (i think they are long) beeps.
Steve
Level 2:
Novelist:
  • Expert 113 Answers
  • Posted on Dec 14, 2010
Steve
Expert
Level 2:
Novelist:
Answers
113
Questions
0
Helped
51879
Points
334
try here:
http://support.dell.com/support/edocs/systems/dime520/en/SM_EN/adtshoot.htm#wp1056390
or here:
http://www.bioscentral.com/postcodes/dellbios.htm#
Is it definitely 5 long beeps?
Ask me for more help.
If the computer is under warranty have you tried the Dell Support telephone number?
Cheers, Steve
ps Feel free to vote for my answer or give a Testimonial if I have helped.
Anonymous
Level 3:
Guru:
  • Dell Master 2,178 Answers
Anonymous
Dell Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390690
Points
6614
Dell loud fan noise
Is the computer completing post? This is indicated normally by a single beep after the power button is turned on. On most computers the beep is proceeded by a post screen with the manufactures logo. If the computer is not getting this far, unplug everything but the memory and video. This should cause the computer to give a no hard drive or OS error. If not pull all the memory, this should cause the computer to give a series of beeps (because there is no memory installed). If this does not work either, you could have a bad mother board or power supply.
Hope this helps
When I turn on my packard bell ixtreme 6052 nothing appears yet it does see computer but does not even go to bios and harddrive read light remains on and harddrive is constantly ticking like it's...
This could be lots of things (bad HD, bad Mother board, bad RAM,etc...) first you need to narrow down the possible cause, open the computer, take out every thing that can be unplugged (I MEAN EVERYTHING) RAM, PCI cards, VIDEO cards, all storages HD, CD ROM, etc... just leave the CPU and power supply plugged in, than power up the computer and listen for BEEP's if you hear a series of BEEP's this means the CPU, power supply and mother board are GOOD, than (with power OFF each time) re-install the components you taken out (ONE at a time) to see which device causes the system crash... I've seen a modem card causing a system mall function once rediculous but true...
My conputer ( desktop ) turns on but no image on the monitor it shows a message no sync. i already tested the monitor and it works fine.
there are several things that could be causing this issue. 1) could be the power supply has died. It may get some fan spin but never power the motherboard. This would cause what you are seeing. 2) could be the motherboard. If the video is built into the mother board it either could be the adapter or the motherboard itself. If you get no beeps or drive spin noises it is probably either the power supply or motherboard. ( I would try to test the power supply first, very often that is all the problem is, just happen to my dad's computer) 3) if you get some beeps and lights it could be just the video card. If you have one on the mother board try plugging another into one of the slots.
Those would be my first 3 guesses, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Inspiron 531s will not boot up, keeps beeping, saying it is in power save mode. How do I fix the problem
System Beep Codes The Inspiron™ 531 / 531s system can emit a series of beeps during start-up if the display cannot show errors or problems. These series of beeps, called beep codes, identify various problems. One possible beep code consists of repetitive three short beeps. This beep code indicates the computer encountered a possible system board failure.
The series of beeps has a 3-second delay before it repeats. The series and delays continually loop until you press the power button.
Code Description Suggested Remedy 1 BIOS ROM checksum in progress or failure System board failure; covers BIOS corruption or ROM error 2 No memory modules detected
  1. If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  2. If available, install a good memory module of the same type into the computer.
  3. If the problem persists, contact Dell.
3 Chipset error (North and Southbridge chipset, DMA/IMR/Timer Error for Intel® platform); chipset error System board failure. Power LED is blinking amber. Time-Of-Day Clock test failure Gate A20 failure Super I/O chip failure Keyboard controller test failure 4 RAM read/write failure
  1. Ensure no special memory module/memory connector placement requirements exist.
  2. Verify the memory modules you are installing are compatible with the computer.
5 Real time clock failure. Possible battery failure or system board failure.
  1. Replace the battery.
  2. If the problem persists, contact Dell.
6 Video BIOS test failure Video card failure 7 CPU cache test failure Processor failure
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Blinking green light on the back of hp pavilion
1. Your smps is OK for power supply
2. check the beep sound for RAM and Video card (If it is long beep the RAM is having and short and frequent the Video card) o
3. Remove RAM then start ssytem see the response shoutdown, clean the RAM place it back start the ssytem
4. Remove the CMOS battery or short the jumber for any setting in BIOS start the ssytem
5. Disconnect all the cables connecting motherboard including Hard disk except SMPS power supply to Mother board
2answers
Dell dimension E310 crash
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
Is motherboard dead?
Either motherboard, ram module or if no power at all sounds more like a power supply. If the computer has on board video you will need the ram to get any video. But with it removed the board should still beep if the case speaker is connected to the board. Have seen a lot of these less expensive motherboards fail. If there is no power up at all or lights coming on on the case I would think it is a power supply problem. Happens all the time and quite easy to repair. Just put on a new power supply.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
