SOURCE: kohler 12kw generator starts but shuts down after 3sec
try to unplug the device and then again plut it after some 5 minites and reset it.
SOURCE: electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
SOURCE: When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
SOURCE: I have a kohler rdt-cfnc-0100b automatic transfer
sounds like the voltage sensor is either mis adjusted or burnt up. Also could be a wire disconnected on the voltage sensor board.
SOURCE: Kohler magnum12 gas generator will not produce electric power
Plug an electric drill into your output power at the generator IF you have a plug at the generator. (Output power CB must be on.) IF not the closest point to the generator and then pull the drill switch and turn the drill in the reverse direction. That will flash the field. 1/2 inch drrill works best but with some effort a heavy duty 3/8 drill will work. Just rotate it quickly... when the generator starts working it will try to yank the drill from your grip so keep that in mind. (Trigger Sw on drill ON)
Kelly
