Canon CanoScan FS4000US Film Scanner Logo
Posted on Dec 14, 2010
I have Cannon Canoscan FS 4000US scaner but do not have sotware driver for windows 7 (home edition). Where I can download driver and how to install it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
599
Points
I use a Canon CanoScan fs 4000us with Windows 7. I Use program VueScan 8.6.63 and a USB-cable. It need no driver.
  • Anonymous Sep 10, 2011
    would I be able to upgrade to windows 7 without loosing valuable data such as family photos and endless videos? We are new parents so of course we have 1000 hours of video saved on the pc. We can't lose it and backing up on a external hard drive I just don't trust.
2helpful
I cant get my Canoscan 4200 F flatbed scanner to work with Windows 7 Home version. Any solution?
You should try downloading the Windows 7 version of the software and drivers for you scanner from the Canon support web site: (click here)
From the "Select OS" drop-down, select either the standard (32bit) or 64 bit version of Windows 7 depending on what you have installed on your system.
From there, download the 4200F Scanner Driver and the CanoScan Toolbox software and select "Open" after download.
Good Luck!
I have windows 7 and the cannon scanner canoscan n124ou is there a driver for windows 7?
Canon has no driver for CanoScan N1240U on its website for Windows 7. But, if you want to try with the one for Windows Vista, you can find it here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
I can not run the canon scanner n640 p ex in windows 7 while it is good working in win xp. so please help me how can i installed??
hello there
you need windows 7 driver of your cannon here the link : http://www.usa.canon.com/cusa/support choose your operating system and download the windows 7 driver of your cannon scanner
thanks
leave a comments
My scaner is epson stylus cx3700 but i can no use the scaner in window 7 what can i do to make it work
Hi semidgs !
Unfortunately , there are no drivers anymore for your device under Windows 7 64-bit system but well under 32-bit system .
Here is a workaround :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
I have installed Windows XP on my secundary ( Windows 7 on primary ) and everything is working fine .
Regards .
I run windows 7, but I cannot get the driver for my scanner - Canoscan D646u ex (yes, i know, its a dinosaur -- but its not broken)
Unfortunately , the production of drivers stops at W XP .
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html. Easy and safe , no specific knowledge required .
Regards
I have flate scaner lide30 7 hv a software which is for window xp but i hv changed to window 7 .how to get drivers for this
window 7 software is not yet available from canon
you may double check from "http://support-sg.canon-asia.com/P/search?category=Scanners&series=CanoScan+LiDE&model=CanoScan+LiDE+30&menu=Download&filter=0"
1helpful
2answers
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
3helpful
Driver para windows 7 scaner artiscan 9600
poseo un escaner CanoScan N 340P, trabajo con plataforma windows 7, no me funciona el escaner, que puedo hacer?
2helpful
3answers
I am trying to install canon flat bed scaner on my laptop windows 7 and I am unbale to locate the drivers for windows 7 (twain) , I intall aarcsoft photo base and it can't locate twain or drivers for the...
Sorry, but the compatibility sites say this is not compatible with Vista or Win 7.
They word is that Canon has no intentions of writing a win 7 driver for this unit.
You should probably backstep to Win XP so you can use this scanner.
These manufacturers are letting Microsoft make the hardware obsolete due to lack of drivers... a conspiracy???,
2answers
I need driver for Cannon 8000 scaner
You can try here for your drivers.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Or if that fails most the time you can go here.
www.driverguide.com
They have a huge selection of drivers, and registration is free.
Hope this helps. M~
old marine
old marine
ZJ Limited
ZJ Limited
