I was running blower with the wrong mix of gas oil ti stoped and would not start how do i fix it.
Check 1. Compression 2. Gas/oil mix 3. Air filter 4. Spark at spark plug. This is just the beginning of troubleshooting a 2 stroke. They develop fuel line problems and carburetor problems and magneto air-gap problems. Critical though is the oil/gas fuel mix that is used. It needs to be fresh and mixed at the correct ratio. Check all these things that you can and post back.
View the troubleshooting chart here, just to show..under Hard Starting/No Start. You will need Adobe Reader to view this Zama carburetor technical guide (many causes for no start). http://www.zamacarb.com/pdfs/TechGuide_2...
For a start, pull the air filter off. Open the choke. Spray carb/choke aerosol spray into throat of carburetor and immediately try to start engine (try this with choke closed). If it pops, then that is a good start and eliminates troubleshooting other problems. If it pops, then the electrical (spark plug) system is probably Ok and we are dealing with a fuel delivery problem, most likely a bad fuel filter, fuel lines, dirty or worn out carburetor.
To
troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
HOT/WARM START ISSUE
Its
a hot start issue.
Can
be related to low fuel pressure or problem with crank sensor.
Also
it can be weak battery or starter.
But
possibilities are to be inspected to confirm what exactly it is.------
To
troubleshoot and confirm the issue,i suggest you refer few solved help links
with similar types of problem like yours:------
Click
the link below:------
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These
details will help.
Thanks.
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://www.howtorepairguide.com
These will help.
Thanks.
It
From
Won't Start?
These will help.
Thanks.
It
From
Won't Start?
These will help.
Thanks.
It
From
Won't Start?
Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
These will help.
Thanks.
