SOURCE: Stop Watch not resetting
DO NOT REMOVE THE HANDS ON YOUR WATCH!! pull crown out to second position then press button on dial you want to zero out. each time you press it, it will move 1 increment
SOURCE: Stop watch hand
You have to reset your watch. Pull out crown to first click and try to move stop watch hand by pressing one of the pushbuttons. If this do not work, push the crown back in. Now pull out crown fully tto the second click and try to manipulate with pushbuttons again.
After resetting stop watch hand to 0 push the crown in completely.
Job done.
SOURCE: The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
