Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Ensignia maytag washer noise
During slow and fat spin cycle, the machine makes terrible loud rumbling noise. Is it the bearing that is worn. If so do you know the part number and how easy is it to repair. Please help. Thank you
  • 1 more comment
  • Anonymous Jul 28, 2008
    I also have a Maytag Ensignia washer, model MAV7557. Last week it started making an extremely loud rumbling, grinding noise in both wash and spin cycles. This noise is much louder than when wheel bearings went bad on my car. I cannot turn the washer drum by hand. Do you think the problem is the drum bearings or the transmission?
  • Anonymous Nov 03, 2008
    Same problem with loud noise. Sears repairman says that the engine is shot and a new one is required. Plan to call Maytag tomorrow to inquire about quality of this particular unit.
  • Anonymous Mar 03, 2009
    my maytag performa make an awful gridding sound when in the spin cycle
  • 246 Answers
The bearings on Maytag Ensignia's are part of the seals that keep the water in. Once you start hearing the bearings begining to go, you likely will have a leak following shortly thereafter as the bearing greased is washed out by your laundry soap. Up front. This is a procedure that requires specialty tools and takes me about 45-60 minutes to complete. The easiest way to tackel this job is to take your model number (just on the back side of the console) and take it to a local appliance parts store. Ask them for a tub seal kit. (I can't give you a part number since there is no model number listed) but they should be able to pull it up for you. When they bring it up to the front, inside the seal kit is not only step-by-step directions, but also the part numbers for the specialized tools required as well. If you opt to go the repairman route, I'll forewarn you, the company I worked for charged around 250-300 for the repair on this. Send me back a message if you have any troubles or other questions.
Posted on Jul 01, 2008
  • booawx3tkx Dec 02, 2010
    this is the same thing my maytag Ensignia is doing, its only 4 yrs old. I just cant believe that this wash machine is crapping out on me and will cost so much to repair. Thank you for your help and I have called to check on the repair price and from what I tell them they say the repairs will be between 300-375 , so I feel I might as well just purchase a new washer and this time it wont be a maytag.
6ya staff
SOURCE:
My Maytag Neptune washer -FAV6800AWW make very loud noises during the spin cycle.
if its a rumbling noise its the bearings which need replacing which is a major job
Jun 29, 2018 | Maytag Washing Machines
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
Why does the Drum spin erratic even without clothes in it?
might be a warped spin basket or the dampers could need to be replaced. could even be a bad spin bearing. if it was bearing, normally would be associated with a loud noise during the spin cycle though.
Feb 27, 2015 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 22, 2014 | Washing Machines
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
During spin cycle washer is making loud noise
If it is making a sound like a loud rumbling sound similar to a jet plane taking off, it probally due to the seal has failed causing water to leak into the bearings. The bearings begin to rust, and no longer round and the noise gets progressively louder. It can be rather expensive to fix. Get a few estimates before deciding whether it is worth fixing.
Aug 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag Performa PAV2200 makes a rumbling sound while agetating. Suspect a worn bearing or belt? Could you shed any light on this?
Yes it could be the spin bearing at the base on top of the brake assembly. I would suspect that the brake assembly is the cause of the noise as this engaged when you the washer agitates. If it was the bearing it would make a loud noise in the spin cycle, too.
Nov 05, 2009 | Maytag Performa PAV2200
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
696 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
