My creative zen keeps freezing as soon as it gets to the first song. i tried using the recovery tool, but it didn't work. i did download all of my music from my itunes. idk. real frustrated.
Hi -
I know this response is way late to help you, but I was having the same problem. I could turn the zen on fine, but as soon as I tried to play music it would freeze and I couldn't turn it off. Using the reset button didn't help any since it would still freeze if I tried to play anything.
But I found reformatting the entire zen totally fixed it.
-directions-
Connect your zen to your computer, go to windows explorer, click computer on the side bar, and your zen should be under "portable devices". Click on it. You should now be viewing the "storage media". Right click and select "Format...". This completely resets the zen, clearing any preferences or media you put on it and the freezing problem.
It was annoying putting all the pictures, videos, and itunes back onto my zen, but at least it works now. Since I've reformatted it, I have had no problems.
Hopefully this helps others who experience this problem.
--Lillian
When you encounter a song that is freezing your zen, you need to delete it from the zen. At that point try to transfer it again. If it is copy protected then you may need to remove the copy protection.
The "iTunes format" is nothing more than AAC. The Creative Zen will play unprotected iTunes Plus tracks as well as CD rips from iTunes (M4A). Any DRM'ed tracks that you may have purchased through iTunes will not play on Zen.
google for "hymn project" or "myfairtunes" for iTunes DRM removal. (And for "FU4WM" for WMA DRM removal.)
Alternatively, you can always burn the DRM'd tracks (copy-protected songs), then rip them so they are no longer protected.
Try the reset button on your zen. you'll need a paper clip to reach it.
that should work; it will not erase your data. -Edward
hey people, there is a hidden "reset" button on the player. it will reset the player and fix most problems. you will need a paper clip to press the small button. -Edward
to find the reset button, download the zen pdf file from the creative labs site; it's free and it will show you where the button is located. -Edward
I had a problem like that 2!!! basically wat happened was my music icon was all the way at the top and everytime i tried to click it it would freeze. this all started after i downloaded a song and put it on my slow jamz playlist. so wat i did was i changed the icon order by switching it to default. 1. go to the main screen where all the icons are
2.press the options button and it should ask this: configure menu, change order, default menu and volume.
3. try clicking default menu. that cleared up my freezing problem. bcuzi dont use the microphone setting so now even that works!!!!!! juss try doin that if it doesnt work then maybe u should try resetting or if its still under warranty take it to the original store where purchased. sry for the late response.
my creative zen is frozen. i will reset it. and it continues to freeze. i left it alone for a few days. then charged it and it still will not unfreeze when i begin playing a song. what do i do.
Whatever software I use (Creative/Mediamonkey etc.) syncing freezes on the first song.
Stangely - copy protected content (WMA) in a separate folder works fine, but unprotected songs (MP3) don't.
Copying files using windows explorer works however.
I've tried updating firmware, reformatting etc.
Any ideas ?
this is not connect properly & i can;t find how do i reset & upgret softwear.
my creative zen has froze and i cannot turn off or do anything.
it keeps freezing
downloaded music off itunes and it freezes and it keeps going to the first song that i had on before but now its not even playing..
mines freezes and wont turn on
mine keeps frezzing wen eva music starts pplaying. wat do i do, i downloaded sum of my songs off itunes
When i try to play any song it freezes and wont turn  off unless i hit reset and then when i go to play another song it freezes again.i already had to return a zen and this is the replacement. am i gonna have problems with every zen i get?
i have the same problem and i tried deleting the song it first froze at and comes up every time i turn it on BUT when i try deleting it it freezes there as well
My ZEN froze after i started playing a record song. I had the headphones in my ears and it made this big buzz and froze.
Every t
My creative zen freezes up everytime i try to play a song...
Whenever i turn on my zen it says rebuilding. After that evertime i try to play a song it dosent play and freezes
Creative ZEN 8gb player will boot up, but kicks off if I touch it, or sometimes as I plug in the headset.
Occasionally, it won't boot up all the way, freezes before the operating screen appears.
Every time i turn on my zed and lock the device and unlock it i can't seem to change my songs except turn my volume up and down. What do i do?
i can only get onto the CREATIVE screen then it just stays there and it wastes the battery.
my crative zen freezes whenever i try to play music what do i do
my creative zen 30 gb's keeps on freasing up it freasing up wether i'm on a video or music and i already have the letest firmware. can anyone help?
iam having the same problum it willl turn on but freezes when i try to play music or watch a videio it started happening when i downloaded a vid on it and it kept freezing but i deleted it on the computer when i pluged it in everything eles works i can get into calinder pictures and all that other stuff jus music and videios make it freez and i have to hit the reset button to turn it off or it just stays frozen
The player freezes as soon as you select "play". Also freezes when you select FM Radio. I reset with the hidden reset button and it rebuilds and then does the same thing (over and over). I tried running the recovery tool, but it hangs up before finishing. Also tried to format the player, but I can't get it to go to the format screen. Help!
My creative zen keeps on freezing. When I turn it on it will go to the first song and freeze. I tried the reset button but that didn't work.
