Hi, I've found something on amazon, take a look: CATERPILLAR Raygo Rascal Roller 600A 3E710 3E973 PTS Parts. Have a nice day
Greetings-
If you are looking for the Owners Manual for your Rascal 600T I ahave provided a link below where it can be downloaded.
http://www.dolphinlifts.co.uk/images/library/documents/Rascal_600T_F_manual.pdf
I hope this helps
an owners manual is not a repair manual.
give me your email and i'll will send you the service manual. yeah i actually got a service manual.
could you email me the service manual for the rascal 600 at [email protected]
John, George or cmyeoman...If any of you have the service manual for the rascal 600, could you email it to me? [email protected].
Thanks in advance
SOURCE: batteries do not charge but charger is working.
mcdevito75 here, You may need new batteries, if they are 2 years old or more.
SOURCE: Rascal 600T motor gets hot.
Check the electric brake its most likely not disengaging from the motor case causing the motor to strain and overheat. You can unscrew the brake assembly from the rear of the motor and check to see if the brake pad is free and moveable If you can support the rear wheels off the ground and engage the throttle you should be able to hear and see the brake pad release. You can drive the scooter with the brake off the motor but do not disconnect the brake wiring. The scooter looks for that connection to work if it can't find the brake then it will flash and won't operate. now if you do hang the brake off the motor remember you do not have brakes and the scooter can roll backwards when going up ramps or on hills. You will have to replace the brake assembly and reattach it to the motor to have brakes
Hope this helps you
