Power outages are not that common.
If I understand correctly, you have or need some kind of automatic delay timer, like the Paragon ET series.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#ET
Or maybe the Dayton off delay timer.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Or you have an occupancy sensor with time delay like the Tork SSA.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#SSA
Is this timer hard-wired into a box, where it gets steady power?
Is the timer supposed to have a back-up rechargeable battery?
If this is a digital Tork box-type timer, most of those timers have a power-loss carryover.
If you can identify your timer, or say more details about how your timer operates and where timer is located, and what fan Load is, I might be able to suggest an alternative that works for your purpose.
Add a comment.
Hi Jessica Yacopino - Generally speaking, Frigidaire air conditioners timer option typically have the same procedure. The unit must be in the ON position for the timer delay stop option. For delay start, the unit must be in the OFF position. First, press time button. Then to adjust timer setting, tap or hold the UP arrow or the DOWN arrow to change delay timer at .5 hour increments, up to 10 hours, then by 1 hour increments up to 24 hours. The control will count down the time remaining until start (8, 7.5, 7, etc.). The Delay Start mode automatically selects cooling with maximum Fan Speed. The temperature maintained will be the same as previously set. To change the set temperature, press "COOL" then Up or Down arrows until the desired temperature is indicated on the display. After 5 seconds, the control will automatically change the display back to the hours remaining until the unit will start/stop. PRESSING the unit On/Off button at any time will cancel the Delay Start/Stop function. The Delay Start/Stop Feature will work until the unit either starts or stops. Once that happens the above steps have to be repeated again.
