SOURCE: need to remove phone password
Hi.
Not sure if this is relevant for your handset model but it may work.
All you need to do is hold down the Send and End Call buttons down firmly and push the stylus up in the little hole near the usb port (Reset Button) and wait till the screen says that the phone is going to format and all data will be lost press the soft key to continue. Then when it says that press the center button and it will show Fat formatting and Rom formatting. This will erase all data on your touch so make sure you back up.
After turn on the phone and go through the set up.
Of course this will erase ALL data that was originally saved on the handset.
Also if the previous owner does not recall setting a password try just typing "1" then unlock. I read somewhere that this sometimes works???
