Toys Logo
Posted on Dec 14, 2010
Where or which page is the dedication page in the recordable book "The Night You were Born". I'd want to record a greeting as suggested in the instructions and can't find it. I am not able to record on the 1st page wher the "To" and "from is located.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
554
Points
Ahhhhh! I'm having the same problem! I never would have purchased this, had I know there was no place to record the dedication!
How do I record the Main Message people hear when they call my company?
Note: Voicemail may ask for mailbox and password. Please consult your owner's manual for the credentials.
To change Main Greeting messages, here are the following steps:
-Go into the Supervisor Options
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
How to change recording on day/ night mode
This depends what voicemail you have, SVM OR TVM. and you need to know what group rings in each mode SVM day *47 (voicemail extension number) (PIN number) *38801 record STORE NIGHT *47 (voicemail extension number) (PIN number) *38811 record STORE TVM voicemail extension number (500 or 200) #6* (ringing group number) option 3 then 1 then 1 follow the prompts
I have a Siemens Gigaset 8800. I am trying to record a personal greeting. (the quick greeting that it comes with is the one playing) I've followed the instructions. The phone responds "empty record
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027395.pdf
http://www.barclayent.com/manuals/Siemens%208825%20Quick%20Start.pdf
Hi please find above links for your user/QS manual.
Now if you have done it successfully in the past and you are indeed doing the exact same procedure, but it fails, then the only conclusion one can come to is that the unit has faulted? I have seen similar types of faults on these and other types before, and they always present the same symptoms you indicate. However use this top manual and go to page 55 and do that procedure, and see if that will work? If it still will not work OK, then you have little option but to get it repaired, use the process indicated in the manual, as to repair. You may like to only first just ask for a "Quote", and once appraised of costings etc, you can then make up your mind as to repair or replace?
1helpful
2answers
I AM UNABLE TO RECORD A PERSONAL MESSAGE ON MY DECT 1580. THE INSTRUCTIONS ON PAGE 11 STATES "1. SELECT COMMAND 8:RECNEWGREETINGS (RECORD NEW GREETING." WHERE IS" COMMAND 8? OR HOW DO I...
On your handset, press the Mute (the button also has an envelope to indicate messages). Press 5 on the handset to stop the playback of messages (if any are on the machine). When the handset beeps, press 8 on the keypad of the handset. When you hear "Record greeting", then speak your message. When you are done, press 8 or 5 to stop recording.
Note the answering machine must be on before you start. Press the On/Off button on the base.
I hope this helps.
9helpful
2answers
Twas the night before christmas recordable book - cannot record first page of text and have it work-second page shows up instead,
I had the same problem with another Hallmark recordable book and figured out it had to do with where the light was coming from when I was turning the pages. When I moved it worked correctly.
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
1helpful
Need to change auto night greeting
llassetter,
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. 3 for greetings, 1 for the auto attendant #. press 2 for night menu and 6 to modify the menu. press *# to skip selector codes.Press 1 to record your new greeting 1 to stop recording. Press *# to approve or 21 to re-record hang up when finished.
hope that helps out
1helpful
How to record greeting message
Page 21 of the manual: http://service.us.panasonic.com/OPERMANPDF/KXTG5100M.PDF
1 Press and hold [GREETING] until
“Record greeting after the beep” is
heard.
2 After the long beep, talk clearly,
about 20 cm (8 inches) away from
the MIC (microphone).
• The elapsed recording time is
displayed.
• If you record for over 2 minutes, the
unit will stop recording.
3 When finished, press
[GREETING] or [STOP].
• The unit will play back the recorded
greeting.
• To change the greeting, start again
from step 1.
1helpful
Uniden448-2
Here is a possible procedure in quick time:
1. Press and hold greeting button.
2. You will hear “Record Greeting”. Start your Personal Greeting immediately after this.
3. When you have finished recording your greeting, press |>█ (play/stop).You will hear a confirmation tone and your recorded greeting plays back for you.
Cheers
Top Hallmark Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Hallmark Toy Expert? Answer questions, earn points and help others
