Question about Tilia Foodsaver V835 Vacuum Sealer
Vacum works heatseal does not seal can i replace seal
    New Friend:
  • 10 Answers
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Posted on Dec 14, 2010
SOURCE:
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
How can I fix the edges of my laminator to seal.
make sure you are at 300 degrees temp, you can slightly adjust the pressure on each side by tightening down the 5mm hex nuts on top of each bearing housing. There is alot of foreign films out there right now that also have substandard glue that are causing all kinds of lamination problems. USA film always works
Mar 13, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Is there a schematic diagram for heatseal ultima 65 I need one.
not that I am aware of, the maint manual has a theory of operation block diagram, but no schematics.
Jan 28, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Why does my break pedal leak air?
You have a bad seal in your break booster unit,, just behind your master break cylinder is a big roung doughnut looking thing, this unit works off vacume from the engine, it helps you push down on the break peddle so its not so tuff to stop! well on that booster unit there is a seal that keeps the unit from loosing vacume past the rod leading into your break peddle, sounds like this seal is leaking vacume .. you can replace this unit your self if you want to tackle it, its going to be some work to replace and you should probley have the manual on this truck to do the work.
Hope this helps! Good Luck!
Sep 13, 2011 | 2004 Nissan Titan
I have a heatseal h425 and it is making a loud sound when turned on. The rollers are not rolling and it feels very hot on the outside of the unit.
hi can you please open the laminator up and tell me if there is a rubber toothed belt on the cogs by the motor then i may be able to help.
May 10, 2011 | Gbc HeatSeal H425 Laminator
My ultima 65 laminator is not sealing well on the left side. I've tried adjusting the upper tension which helps temporarily, but it reloosens after just a few minutes of use.
By "upper tension" do you mean the hex screw located inside the left panel? If you tighten this until there is no space between the heat rollers it should eleminate the problem. If it is continues to loosen, back the screw out, apply a small amount of locktight to the threads before replacing the screw.You can find locktight at any hardware store usually in the Paint section near the glues. Hope this helps. Good luck
Feb 16, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Hearet problems
this is useally done with vacum pressure I would check my vacum lines
Dec 28, 2008 | 1966 Ford Mustang
Tilia Foodsaver V835 Vacuum Sealer Logo
2,467 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
elementsandt
Level 1 Expert
Sheldon Dedek
Vitally Alcher
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
