Manual and image for Woods/Noma N1506 outdoor timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
Timer is only set to nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press
time button repeatedly until required ending time appears in the
window. (Note: a dot at the bottom right corner of the display indicates
P.M.hours).
Press Mode button and the display returns to the current time.
Programming
is now complete. You may now plug in whatever needs to be turned on.
The device will turn on and off automatically every day at the times you
have just selected.
TO REVIEW THE PROGRAM
Press time button -
Displays successively, for 1-2 seconds each: P, starting hour and E,
ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug
the timer, which will discontinue the current program. After 10
seconds, plug it in again and proceed to set current time. Then continue
with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing
the Mode button at any time will turn on the devices plugged into the
timer. The display will indicate the letter O. The devices will remain
on until the ending time of the daily program. To return the timer to
the automatic mode prior to that hour, press the Mode button again. The
display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
