Mitsubishi WS-55819 55" Rear Projection Television Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model WS55819, shut off and won't turn back on. The first few times I tried to turn it on, the indicator light came on and went off after a few seconds. Now there is nothing. I removed the panel from the back and checked power in, which is good.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Dec 13, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957463
Points
33084
Most common problem in WS-55819 is failure of convergence output chips and blown pico fuses in power supply section.
You need to read out error code in tv, procedure is as follows:
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "24", the LED will flash two times, pause, and then flash four
times.
Error codes detail:
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
This way you can determine what section got problem in tv and causing problem.
Let me know if you need further info.
Thanks.
MY COMPUTER SHUT DOWN UNEXPECTEDLY AND WON'T TURN ON AGAIN
I usually try to hold the power button for >5 seconds to reset it. No lights even when plugged in?
2003 kia sorento keyless entry not working
If both remotes light up and don't work even right next to the car, the car and remotes may need to be paired again. I found where someone mentioned disconnecting the car batter for more than one minute but less than five and seeing if it works again. If not, you may have to get it checked at a dealer. Most of these fobs are only programable with special tools at the dealer. I've purchased nissan oem fobs new on ebay, but still had to pay the local dealer to get them to work.
I have this tv and I went to turn it on and the green light flashed about 5 times and then shut off. I have no picture or sound. Anyone have any suggestions
Says here its a RCA, model indicated is a very bad set====blinks indicate it is in shutdown because something is wrong.
Confirm model number and a guess of age of set (both are on the back of the set)
Reset oil light
If you have steering wheel controls you can reset it by getting to the oil life indicator (mine is on the left side lower button menu when wheel is facing forward). Then press the arrow button for a few seconds to reset it. If you don't have steering wheel controls you can reset it by turning key to on position but don't start vehicle. Press gas pedal all the way to the floor three times (some say 6 times). Turn key off. Oil life should be reset went you start engine next time. I hope this works for you.
Model WS55819: Shut off by itself. Power ON with remote, Green light next to power button on TV flashes twice fir 10 cycles and shuts off. Unplugged TV for 30 minutes and for 4+ hours. Same results.
you will have to count the blinks, then there is a short pause and then following a second set of blinks this tells what is wrong with set.
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
I was playing and my system shut off. the indicator light was blinking red. i hit the power button once and the indicator light went back to a solid red light. i tried turning the system back on and the...
You need to have the motherboard fixed, do to so you need to take the PS3 apart then reflow the board.
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video about 10mins long, goes over everything for you.
http://www.youtube.com/user/gilksy1 and its free unlike some eBook site.
I actually used the videos shown by this guy to fix about 30 PS3 units with no problems, you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
15helpful
2answers
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
