2003 Lincoln Aviator Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2003 Lincoln Aviator emissions light is on and I failed inspection because of it. How can I pass inspection and fix this emissions problem? The inspection code given to me was PO420???
Anonymous
Level 3:
  • Lincoln Master 3,640 Answers
  • Posted on Dec 13, 2010
Anonymous
Lincoln Master
Level 3:
Answers
3640
Questions
6
Helped
1676137
Points
10518
Po420 is catalyst system efficiency below threshold. meaning is--- could be down stream 02 sensors or a bad convertor. try buy replacing down stream sensors, hopefully this may help. ( down stream 02 sensors are between convertor and tailpipe). have a good day !!
I have a Lincoln aviator 2003 my driver light flashes
Lincoln Aviator drive light flashing Questions & Answers ...
www.fixya.com > ... > drive light flashing > Cars & Trucks > Lincoln
Lincoln Aviator cars & trucks drive light flashing questions and answers. ... 2003aviator check engine on why? car has brand 2003 aviator check engine is on ..
2answers
2002 Lincoln Aviator engine shaped warning light lit on dashboard-what is problem-how to diagnose?
This lamp is yellow it is the check engine light for your emissions control ther is plug under the dash in drivers seating area 16 pin connector called a DCL Data Communications Link with a scanner you can retrieve trouble codes for repair.
1helpful
Emission light staying on in 2003 Lincoln LS not sure why??
Google your codes- to find out the system
with the fault & what it is
2005 Lincoln Aviator - Hazards and Signals don't work
On the Lincoln Aviator there's a set of fuses under the dash of the vehicle. One set has to be dropped to get to the flasher fuse.
3helpful
How to replace tail light on Lincoln aviator
Here is a web site that will tell you in detailed instructions on how to replace your taillight on your 2003 Lincoln Aviator: http://www.ehow.com/how_2631_replace-tail-brake.html
2003 lincoln aviator engine knocking noise
You're going to have to have someone visually inspect it. There are dozens of possibilities and we can't honestly give you a fair assessment. Have it looked at by a competent shop.
2003 Aviator: Button on the gear shift lever will
Yes, there is a switch on the brake pedal that could have been knocked loose or broken. There is a solenoid lock on the shifter lever in the transmission console. Here is a big post on it from a paid advice sight. https://www.justanswer.com/ford-lincoln/3ohnl-2003-lincoln-aviator-frequently-locks-park-gear.html
1helpful
2answers
3helpful
2answers
Rough idle and engine light is on my 2003 aviator 4.6 engine
If there is an Auto Zone around your area, have the truck scanned for the DTC codes which is causing your idle problem. There are to many things that can cause your trucks idle to be rough. Once you have it scanned, we can address the issue and have your truck running 100% again. Auto Zone scan free of charge and can give you the step by step instructions to repairing and replacing the parts needed. Good luck and keep me posted, be glad to help.
How to change a burntfog light lamp
U must crawl under the front bumper, the lights come out from the rear.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
