hi im not an expert but recently had the same problem. i had a blockage in the drainage pipe its fairly straight farward to fix and you tube show you how. hope this helps.
Your Convergence ICs have likely failed. It is very common on rear projections. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Use this simple test to verify. Go to the users menu on the tv. Look for the converge option to align the red and blue colors
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section. If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
I would recommend that you go to adobe website and download adobe reader again. You may want to uninstall the one you are using now but not really a necessary.
This question shows you want password,but we can help you by some theorical process like, you want to go the home where the computer exist and find kernel.
This is most likely going to be a failed hard drive. Since it won't load the system, by general rule, If the hard drive won't format, or if you have any issues during or after the set up of a new operating system, then the hard drive is shot, and needs replaced. Replace the drive and you should be just fine.
