There is no relationship between the air conditioning system and the gear box in the vehicle.
The engine operates the aircon compressor via the serpentine belt from the crankshaft pulley and if the aircon is operating normally the aircom compressor will not be faulty either.
If you are having problems with the gearbox it has nothing to do with the aircon system. The issue will be with the gearbox itself.
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH
2HP LG Window Type Aircon Manual
2HP Koppel Aircon w/ remote model: KWR-18R1 or check the internet for other models that you want.. :)
first engine light is on a reason it has a code stored needs to be read,2.sounds like it needs throttle body cleaning,and3.if clutch is hard means master clutch cyl is bad if hydraulic and if manual cable is worn.
