fan blowing seems like compressor wants to kick on but don'talready cleaned filter clean what nextfan blowing seems like compressor wants to kick on but don'talready cleaned filter clean what next
Re: Frigidaire air conditioner - no cool air coming out.
If you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Try the following to begin operating the air conditioner:1. Plug in the air conditioner. (To prevent electrical hazards, do not use an extensioncord or an adapter plug.)2. Set the exhaust vent to the CLOSED position.3. Press “On/Off” button to turn unit on.5. Press Mode “COOL”6. Press “TEMP/TIME” up or down V to the desired set temperature.Review the “Air Conditioner Features” section for other settings
www.theairconditionerguide.com > BTUs An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing.
common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize.
Have the fan motor checked.
The fact that the fins are freezing, means that there is enough freon and the compressor is working.
I have had the unit for about 5 years.
how long havce you had this AC unit ?
