Panasonic KX-T7730 Corded Phone Logo
A
Anonymous Posted on Dec 13, 2010
How do I record or change a recorded message on the Panasonic KX-T7730?
Carl Navarro
Level 3:
  • Panasonic Master 2,460 Answers
  • Posted on Dec 13, 2010
Carl Navarro
Panasonic Master
Level 3:
Answers
2460
Questions
Helped
1155804
Points
7314
A Panasonic 7730 phone operates on 18 different Panasonic Key Systems. There are 5 or so different ways to record a message...which one is yours?
The 7730 was first delivered with the TA-824 system. It has the ability for announcements via DISA, which was built in to the USA versions of the TA. It's recorded or changed via the master phone and PROGRAM 911.
A Panasonic TVA or TVS voice mail system does auto attendant functions. It can have both company greetings and custom service messages. Those are changed via mailbox 998, the message manager's box.
Last, the newer system also have "bulit-in" voice mail boxes. Those greetings are recorded by 722xx commands.
Carl
  • Carl Navarro
    Carl Navarro Dec 14, 2010
    There's a complete answer in there. Why do you rate questions without comments? Your phone is just a terminal on a Panasonic system. It has NO MESSAGES in it.
2 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Sep 22, 2008
SOURCE: How to record miscall on Panasonic kx-t7730
It depends on your phone system.
If you have a TA system it requires 2 or 4 CO (buttons with lights) buttons. Personal CID Log is
6 for indications and 7 for selection. Group is 96 and 97. You don't have to have a SELECT button but it helps.
If you have a TAW or TDA system you only need one button per feature because the navigator key works as a selector button. The code is 54 for personal and 54 plus the ICD group for system.
The sequence to program these buttons is PROG button CODE store
Carl
Anonymous
  • Posted on Oct 28, 2011
SOURCE: how to record a message on the panasonic KX-T7730
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
I have here six KX-T7730 Phones. I try to set up a new company greeting message. How can first review the old one and delete. The n Ihave to record an another voice. Advanced Hybrid System KX-T7730
Try using the programming software if you have them. Otherwise, there is a procedure on the manual if you have them. I use to download the manuals on the Panasonic webpage.
2answers
I need to delete the message on my panasonic answering machine KX-T7730
The KX-T7730 isn't an answering machine. You need to refer to the documentation for whatever answering/voicemail system you have it connected to. Alternatively, repost your question specifying the make and model of the answering/voicemail system.
Free instruction to record my voice kx t7730
The 7730 is a PHONE. It connects to a Panasonic PHONE SYSTEM CABINET and Panasonic VOICE MAIL SYSTEM. The voices you hear are stored in the VOICE MAIL SYSTEM and it varies by model number and installation. Typical messages are stored in CUSTOM SERVICE menus, of which there are
100.
It is changed by accessing mailbox number 998 as message manager.
Carl
How do I change message played to incoming calls on a panasonic kx-t7730
Try finding out what's playing the message and change it :-)
It could be the DISA card from a TA-824, or it could be the Custom Greeting or Company message from a TVS or TVA voice mail system, or you could be talking about the "on hold" message that's plugged into the MOH port of the Panasonic system.
Once you find out, you can change a DISA message from the first extension 101 by following the programming, or from the Message Manager's mailbox (998) of the VM system, or the file recorded in the on-hold device.
Carl
KX-T7730 Problem
Try to delete both or reseting to phone settings
2helpful
2answers
Changing the recorded message
If all you're looking to do is change Laura's message, walk over to her phone and dial 165 on the intercom. Log into the voice mail where she gets her messages and try different options, like maybe 5 2 or 5 1 to change the greeting?
It will play the existing greeting, let you press 1 to change it. As soon as you finish speaking, press 1 to stop recording and 2 to accept it and it's changed.
Carl
2helpful
3answers
What is the code to record a welcoming message
what system are you using? is it a mailbox or a company greetings?
5helpful
Changing company message on KX-T7730
hi there! can you please help me? how can I create/record a voice message? Thank you.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
