Question about Lanier VW-160T
I know the belt is worn out. I replaced it with a rubber band. It worked, but I need the correct belt for it. Although if you can give me a site that sells the belt for the Lanier VW160T, I will order it myself and replace it. If not, is there anyone on Maui that can replace the worn out belt for the cassette? I need this repaired as soon as possible, if possible here on Maui.
3 Suggested Answers
SOURCE:
SOURCE: I believe my Lanier P135 micro-cassette recorder
Office Automation in Chicago has a great technician.
phone is 312 739 9800
they are very reliable too
Posted on Apr 09, 2009
SOURCE: Need repair for several Lanier p160 hand held recorders
Medquist is running out of parts for many tape machines (Medquist bought Lanier). It is getting harder and harder to find parts. Medquist isn't having any more parts made for many models and has stopped selling the parts. Our company has been repairing dictation/transcription equipment since 1914 with Thomas Edison's original tin and wax cylinder recorders. Due to our business over the years we have a sizeable warehouse of parts. Although for some models, parts are getting scarce even for us. If you would like your tape units repaired, go to the website below:
http://www.vanausdall.com/support/
There is contact information there. Someone will assist you with instructions on sending in your units and answer your questions. Depot service rates are $75.00/hr charged in 15 min increments. Many problems with tape units can be repaired within 30 mins. It just depends on what is wrong. Of course you'll have to pay for parts as well. If we take the time to diagnose the issues with your unit and look up parts and you decide to not have it repaired, there is a $20 estimation fee. As long as parts are available, we will warranty repairs for 30 days. If a part becomes unavailable, of course we can't repair it again under warranty if we can no longer get the part.
Posted on May 01, 2009
Not ejecting
If you are in the UK cpc will sell you a belt but getting in there is a different ball game. Take it to someone competent
Jul 09, 2014 | Sony MDS-E10 Mini Disc Player
Disk will notcome out
Hi Carol,
This is an educated guess but if your deck is older there are eject mechanisms on them. They are belt driven if they are stretched out or broken the disc will not eject on most of them.
Depending on age the belts which are glorified rubber bands last about 10 years or less then need replacement so my best guess is the drive band for the ejector is in pieces in your deck.
Replacement bands are available on ebay, this is not the only possibly answer to your problem but my best guess from your limited description. Note you cannot replace a broken band with an o ring or rubber band or a similar band as they will not work correctly...
Apr 11, 2014 | Sony CMT-HP7 CD Shelf System
Sony mhc vx 901
My best guess is the loading belt (famcy rubber band) to pull the tray out in yours is worn out.
Note you need to replace Sony belts with the exact belt or it will not work. You probably can find your belt on eBay, if not available in North America click international search as the Germans have several places which carry exact replacement belts.
Jan 08, 2014 | Audio Players & Recorders
Hi my mixer suddenly wont spin and im not so sure how to fix it.
if its like mine the belt or pulley wear out mine took 8 years for it wear out. i couldnt find the parts so i took of the base(make sure its unplugged) remove the belt(hold one side of belt over the large cog and turn the cog, the belt should fall off) get a large rubber band (the width of the pulley)and twist the band over the pulley a number of times until it fits tightly over the pulley, replace belt and base and it should work.
this will work if the belt or pulley teeth are worn
my wife still cant beleive it worked
Dec 19, 2010 | Kenwood Food Processors
A part came off and dont know where it belongs
You will need to lift felt on the platter section exposing the platter. Next you will need to pull upwards on the platter itself. The rubber band goes around the inside of the platter and onto the spindle motor. To replace, simply lift platter section of the unit, place the belt around the inside of the platter and replace the platter. Move the platter around till you see the motor and use some tweesers to pull the belt over the motor. Hope this helps
Apr 17, 2010 | Sony PS-LX250H Turntable
The rubber band under the record player has come off
I am not familiar with your particular model of turntable, but typically the belt is easily accessible under the platter (rotating metal disc). Remove the platter (it often just lifts off, but don't force anything) and then you will be free to reattach the belt. Good luck!
Aug 25, 2009 | Panasonic Technics SL-DZ1200 Turntable
Sony CDP-CX300 How To Replace Drive Belts?
The Sony call center says the two belts are the same size. Supposedly, there is a third belt "under the motor board" but I have not been able to find it. That is the 42x1.2 (4219362601). The two easy ones to replace are 421606101 and only cost 1.95 from Sony.
Aug 08, 2009 | Sony Audio Players & Recorders
The rubber band that turns the roller on the vacuum keeps breaking. I just bought a new rubber band, put it on, and it broke immediately. Can it be fixed?
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I see there could be 2 problems – either your revolving brush has hair or thread buildup in the ends of the brushroll of which is causing the belt to break and would need to be cleaned out, or check the bearings on each end – they could be **** as well, or the motor shaft or motor assm is not tuning freely and in that case the motor should be replaced and it is not the belt – one other thing is to make sure the motor is in there securely. Once you get the belt on then roll the pulley and the belt together to make sure the belt is on correctly if the brushroll spins freely.
Apr 18, 2008 | Vacuums
NEED A NEW DRIVE BELT (RUBBER BAND)
I had this problem. The drive belt that lifts the disc reader was too worn out to lift up to the disc. I replaced it by taking a regular sized baloon and cutting off the rolled up piece on the bottom. Worked  great in place of a belt.
Jan 29, 2008 | RCA DRC350N DVD Player
Lanier VW-160T Logo
53 people viewed this question
Top Lanier Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
