Hi, Dayne here,
If your tub has an air switch, it could be the push button, but more likely the air switch. Disconnect the tubing from the button and give it a light puff of air. If it turns on the pump. it is the button. If not, listen and veiw the air switch as you give it a light puff again. If the switch contactors close, the switch is probably good, and it unfortunately may be the pump. Remove and have it tested after looking for a reset or manual over ride by the air switch.
Thank you.
