No turning on and off, or unplugging does not work.
There's absolutely no jam in mine but keeps saying ADF jam. Hope someone, anyone will get pass the suspicion that we MX-320 owners don't know what we're talking about, and are all dumb not knowing how to clear a paper jam. This is a known and super common glitch... There's gotta be a fix somewhere...
NOOOOO! Turning on and off, or unplugging does not work. Wouldn't anyone have tried that before spending the time to post a question?
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
Document jams in the ADF (Document Tray)
Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
When rescanning the document after clearing the error, rescan it from the first page.
Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass.
Document jams in the ADF (inner side)
Document jams in the ADF (Document Output I have a Cannon Pixma - pulloutofslot.gif/>
If the document is jammed in the Document Output Slot, pull it out.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Sorry for taking so long to get back to you; still learning my way around FixYa. If the jam is cleared, you need to reset your printer.
Solution: Press ON switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
On the operator panel, press the
Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
Wait approximately ten seconds and then press the
Wait until the device has completed its cycling process before submitting another job request.
Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
Would be interested to hear if this helps.
what if there is no foreign object anywhere in the machine how do I fix it then?
