With no belt movement odds are it needs a Motor controll board. It could possiably be a bad motor. Pull the red and black wires from the motor to the MCB, hook the wires to a cordless drill battery, if the motor moves you need a MCB .
I just repaired this on my F80 after the factory sent out almost all new replacement parts. In the end, this is what fixed the problem: (This will be easier if you use a friend).
1. Remove the shroud on the motor (at the front of the treadmill) by loosening two screws at the front and one on each side (Phillips).
2. Find the greenish control board (looks like a motherboard kinda). Locate a small green light at the top left of the board. With the machine on, slowly push the belt in the normal direction. The green light should flash.
3. If it flashes single flashes as you slowly push the belt, go on to #6.
4. If it double flashes as you push the belt, find the speed control. It is mounted on the opposite side of the machine from the board, near the edge of the front belt roller (on the left side of the treadmill if you're using it). It's a little black piece of plastic mounted with one phillips screw on the side of the motor box. Loosen the screw and adjust the speed controller as far as it will go toward the belt. It should be lined up parallel to the front roller edge. Now check the green light again by pushing the belt slowly. If it still double flashes, adjust the speed controller location a fraction of an inch back. Keep doing this until the green light only gives a single flash as you slowly push the belt. (I know it's tedious, but it's the only way).
5. Now try the treadmill. If it works, you're set. If it still throws a LS1 error, go to #6.
6. On the greenish control board, locate a round "diode" thingy with a blue top and a tiny round white phillips screw adjustment on the very top. This will probably be on the left side, center of the control board.
7. Turn on the machine and run the manual program at the lowest speed (.5 mph). Using a very small screwdriver, while the belt is running (CAREFUL!), adjust the tiny screw adjustment in very small increments clockwise. (If the screw were a clock, adjust only one clock number at a time). As you adjust, watch and listen to the belt and rollers. When the belt and rollers begin "surging" (you'll know it when it happens), back off the screw adjustment until the surging stops.
8. Stop the treadmill and have a friend get on. Using the manual setting at the slowest speed, have the friend walk on the treadmill. If it's surging or jerky, stop the walking and adjust the screw. Continue to do this until the belt is running smooth and there is not jerking.
9. Turn off the machine and restart. Try it out CAREFULLY! If needed, redo the calibration program. You should be all set.
Hi, check the 12pin communication cable
