Patton MH761 Utility Heater Logo
Posted on Jul 15, 2017
Patton MH761 coil wire can these be replaced? The wire only heat about an 1/8 of the total length and does not produce much heat. I asked about it at the local hardware store and they indicated that the heater sell for about $20, just buy another one. It would seem a hardware store would stock a simple item like this that could be replaced. Are they available anywhere? I do not want to throw it away if it can be fixed.
3 Related Answers
A
Anonymous
  • Posted on Jun 09, 2008
SOURCE: Patton ceiling heater Model# 2433
x48987
Anonymous
  • 9 Answers
  • Posted on Jan 20, 2009
SOURCE: I have a small space
Not worth fixing. Take $20 and buy a new one.
Anonymous
  • 43501 Answers
  • Posted on Jan 16, 2011
SOURCE: my Patton PUH680 space heater is not working. Do
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
3helpful
2answers
I am having trouble fiquiring out which wire goes to which plug. The wires are different lengths and the correct wire length has to go specifically with the correct plug. I have the firing order dia
The firing order is 1-2-3-4-5-6
Cyl #1 is front left when looking at engine front to back
left coil pack connects to cyls. 5-2
center coil pack connects to cyls. 3-6
right coil pack connects to cyls. 4-1
It doesn't matter which connector on the coil you use just that the cylinder is connected to the proper coil pack (the coil fires both plugs at the same time, twice per each full 4 stroke cycle)
1998 Chevrolet Lumina
The coil has apparently burned in half. ineed to know where to find a replacement coil wire
Patton PULikely you will be paing as much for the part, as for a new one! I see the listed for $40-- How old is it?--
Here is an ad thtHere is an ad that might help:
Ads by Google Hydronic Heating Supplieswww.AllPartsHeating.com/PartsGet All Major Brands Of Furnace Parts At Great Prices. Buy Online!
Mack B
PaHere is
1helpful
2answers
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
My Patton PUH682 utility heater from 2011 is otherwise in excellent condition but Auto Safety Shut-Off seems to be a design problem. My overheat sensor quickly shut off the unit when surrounding air was cool. It is inside the bottom of the fan box wired between the on/off potentiometer and heating coils.
I identified it by turning on the heater and watched the metal contacts separate as it tripped. On my unit, the defective overheat sensor is hardwired. Since it was otherwise useless as a heater, I decided to jerry-rig it and hope for the best. I pried back the sheet metal edge of the fan box and wrapped the sensor with electrical tape. Then I took a very small squeezable metal paper clip and lined it with electrical tape. I clamped it over the overheat sensor and it fits perfectly to prevent the metal plates from separating. Now the heater works the way it should. The cable, coils and plug don't overheat on Hot setting and it runs continuously.
My Patton PUH680 space heater is not working. Do you offer replacement coils?
heatman101
Do they use a lot of electric?
Oh yes depending on the draw amps they can run you an extra 50 bucks a month using it 4 hrs a night .
2answers
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
No heat is produced on any cycle
Check the fuse located in the back of the dryer. First unplug the dryer. Then take the back panel off. Now look for a white or tan piece with two wires going to it. It's about 3/8" wide and 1 1/2" long. This is your fuse. If you have no way to test it. You can connect the two wires going to it together, tape them so that they will not tuch anything and short out. Turn the dryer on and see if it heats. If it does, dont leave it like that. It a fuse. A safety devise. Replace it before you dry a load.
3helpful
4answers
When the alarm on the Patton Electric Heater sounds, whay does one do to fix that?
This heater was the determined cause of my total loss house fire. I thought the company would atleast help me find some where else to live, they seem to care. But, as of lately they are doing nothing.
I am told this heater-(prh11- 2008 model- purchased at walmart for about $27.00)
- Had wiring that wasn't up to standards
-1/10,000 units cause fires
-something wrong with the heating element-stops working
- wouldn't stand level
-heating coils
-fires like mine have happened to a few other people
This came directly from a person at Jarden corporation(aka patton-sunbeam)
2answers
Coils not all working
the heating coil may be broken and shorting out to the case. it is a nichrome resistance wire. replace it.
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
