OK!!
DELETE your drivers via Control Panel / SYSTEM... install a 'fresh driver set'...
I found MANY drivers for ALCOR:
https://pcsupport.lenovo.com/us/en/downloads/ds031997
IT is the LAST Link below ~ try it FIRST!
I found "GATEWAY" driver sets for your specific CARD READER, but it's for a VISTA 64 Bit O.S. The address is here.
http://www.gateway.com/gw/en/US/content/drivers-downloads
It reads:
"CardReader Alcor 15 in 1 Media Reader Driver 2.02.01.01 6.0 MB 2010/07/21"
The Link below may not work for you and if not, use the address above. Also know the the SEARCH function at GATEWAY is BROKEN ~ so you may need to 'drill down' to the download link?
> Desktops
> GT Series
> GT4010
> Operating System
> Windows VISTA 64
____________
ALSO DO a GOOGLE SEARCH FOR:
Card Reader Alcor 15 in 1 Media Reader Driver
You should have around 169,000 HITS ~ and maybe you will find a newer/better driver from one of them?
Drivers Downloads
Download Gateway GT5082b Alcor Card Reader Driver 2 01 03 01 for Windows...
THIS ONE!
SOURCE: Gateway GT4010 bootup disk
If you have good internet access, you can download a live Linux distribution such as Knoppix, and burn the it to CD. Don't let the word "Linux" scare you out of this, Knoppix is very user-friendly. And there is loads of resources available online. Anyway, burn the CD, and boot the computer from it. It will take a little time to boot, as it is a live version running only in RAM. It has very powerful applications though, and you can access your hard drive from it so long as the drive is not corrupted beyond readability. If you can access the hard drive, you can view your files, and copy the files to a USB drive. Once you have your data, you can then shut down and restore windows if the drive will cooperate, or install to a new drive if necessary.
!!! Knoppix will not write to or erase any data from your hard drive without you give it permission to do so !!! It is about your safest option in that respect.
Just google Knoppix to find download sites. Most sites have instructions for downloading and burning your copy. And it's all FREE!!!
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
SOURCE: Reinstalling Windows XP Home Edition on Gateway 500XL
Do you have access to another internet connected computer that you can use to create a "slipstream" installation disc for XP. It will make your life a whole lot easier, and save hours if not days of downloading updates. Please read this article, and if possible, follow its instructions. http://www.theeldergeek.com/slipstreamed_xpsp3_cd_final.htm
Also, be aware that you can download all the original drivers from the Gateway web site if you use the serial # to look them up. The serial number is usually on a sticker on the side of the front of the tower near the CD drive. If you don't have the original CD with Drivers written on it, you may have to download these in order to get back online, etc once you load the OS.
SOURCE: My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Testimonial: "If I keep swapping parts to isolate the problem, then I have to buy these three parts, that could be not worth it. Should I just buy a new PC?"
SOURCE: GT5408 PC - SD media reader does not work when
Check The jumper of camera in the motherboard
SOURCE: I have a Realtek HD audio driver on my Windows XP
Make sure your input and out put device is set to Realtek HD Audio Input; & Realtek HD Audio output, respectively, in sound and audio device settings.(under voice tab) Next ensure there are no ticks in the boxes muting your mic, & finally make sure you volume sliders are about half way up.
