Noma/Woods timers are re-packaged under other names and numbers, and appear across several brands.
I don't show a 3-button timer except for Stanley
Stanley 3 button timer:
http://www.amazon.com/Stanley-38468-TimerMax-Extreme-Temperature/dp/B0020ML758
Westinghouse manual seems to match the Stanley timer
http://waterheatertimer.org/pdf/28468_TimerManual.pdf
Woods timers and manuals are shown on page below:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Woods has 2-button timer N1506
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
Woods has 1 button timer N1502
http://waterheatertimer.org/pdf/Woods-N1502-manual-english.pdf
UPM makes 2-button timer
http://waterheatertimer.org/pdf/DT523-Manual.pdf
Write down what displays when each button is pushed, and then add a comment and I'll try to decipher the buttons.
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.To Connect/Operate the Timer: Plug device in to the timer and turn the device on.
To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.
To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.
Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
