Http://avantidryer.weebly.com/store/c1/Featured_Products.html
I bought my belt on Ebay. Easy swap with a Phillips.
SOURCE: Need a belt and felt filter filter and dock for my
Call 800-220-5570 to order parts from the manufacturer..
SOURCE: Avanti D24 dryer....manual on how to install new
go to the link below for instructions with pictures of th ejob.
http://www.diynetwork.com/how-to/how-to-replace-a-dryer-belt/index.html
SOURCE: I need an exhaust filter for my Avanti dryer.
I've seen two indoor vent kits that on Amazon that people use with this dryer.
http://www.amazon.com/Dundas-Jafine-TDIDVKZW-ProFlex-Indoor/dp/B000DZFTC6/ref=pd_bxgy_k_img_b
and
http://www.amazon.com/LTF-Supurr-Flex%C2%AE-Lint-Trap-Kit/dp/B00009W3HD/ref=pd_sim_hi_6
Hope that helps! :)
SOURCE: dryer on but no heat(
SAFETY FIRST UNPLUG DRYER......if its
running then all thermos must be intact so it has to be two things: 1) the heating coil
take the unit apart make sure the two heating points still have the
cables attached and coils are intact, if they are 2) then find the thermal fuse and bypass it, take the two electrical connectors off the thermal fuse and tape them together( this is just to test, once done disconnect them as it is a safety feature and left bypass will cause a fire) if it heats then a new thermal fuse is in order>
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
