I uninstalled and reinstalled the driver and this problem of the switch blinking and showing offline keeps coming
You can't post conmments that contain an email address.
There is that interactive services dialog detection that appears and no printing is detected anymore .. it prints but nothing appears in the piece of paper. i am pissed off with this.
If you can't print from your Epson printer because it shows a 'Printer Down' alert, then learn how to get an Offline Epson Printer Online or make any changes to your printer settings, and you'll get your printer back online and you can resume printing your documents again. If you're using an Epson offline printer, patch windows 7, or windows 10. Then you can quickly fix the offline printer issue with the built-in toggling option between offline mode so that you can get your Epson printer back online.
Epson Printer Offline Windows 10 normally applies to a printhead issue and the displayed error message will flash on the screen. The lights will begin to blink as a symbol of this Offline 10 window. Caused by any international garbage inside a printer roller or due to a paper jam in a printer and many other PC reasons.
(If you want an instant solution to this error you can check our method or contact our Printer Expert team.)
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels. Activate head cleaning before a test is taken .
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
If it used to work, then try unplugging and
reconnecting the AC power cable for USB scanners. No guarantees at all,
but it may work. Unplugging and reconnecting the Firewire cable in XP
also sometimes works. Give it a few seconds to be detected.
Check in the buffer and cancel all the print commands. Open the properties and do the ROLL BACK of the drivers. And try to take a test page. Open the control panel, click on printer and check whether it is offline or onling. Uninstall the printer from ADD/Remove and reinstall it either through a Driver Cd or by online and restart the computer. It should work after that.
go to start and control panel, choose option for Printers and under that you will see the Printer listed. You just have to make a right click on the Printer and choose option "USE PRINTER ONLINE"
First try reinstalling drivers for your printer from original CD, if that doesn't help update your drivers from the Internet.
If none of it helps, try connecting your printer to another computer and see if it will behave the same. If it does, then printer is ready for retirement.
Blinking lights on the printer normally indicate a hardware fault. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859572&lc=en&cc=uk&dlc=en&product=1100995&rule=19351&lang=en is the HP page with more info. You should be able to get an error message from your computer, the details being on at that webpage.
