Panasonic KX-TG2356 Cordless Phone Logo
Posted on Dec 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHEN A CALL COMES IN THE RECORDER SAYS THAT IT HAS NOT BEEN SET UP. HOW DO YOU SET UP THE ANSWERING MACHINE?
Radio Code Pro
Level 3:
  • Master 2,200 Answers
  • Posted on Dec 12, 2010
Radio Code Pro
Master
Level 3:
Answers
2200
Questions
0
Helped
642735
Points
6531
The answer to this is quite involved. You must first prepare the answering system, decide if you want to record your own personal greeting, how long you want the actual recording time to be and number of rings before the machine answers and then set the system to answer on.
This whole process is quite involved and takes up several pages which is impractical to reproduce here, so rather than copying it all here I am providing a link to the manual for this phone.
Please refer to pages 20 to 24 inclusive and 52 to 56 inclusive regarding how to set up the answering machine and how to listen to playback of messages. Link is below;
http://service.us.panasonic.com/OPERMANPDF/KXTG2356.PDF
Thanks for using FixYa. Please remember to leave a vote for the solution.
1helpful
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
5helpful
2answers
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
2answers
How do I make answer message
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
CapitolA is on the base and the answering doesn't record
Not sure if this will help with your query but it may be similar to the problem I had with a wireless home phone with answering machine not taking messages when I had the answering machine set to 12 rings before answering. Found the sim card (my wireless system) auto response would answer first. Fixed it by reducing time for the answering machine to come on to 6 rings and answering machine now comes on first.
1helpful
Not recording
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only)
3) Press the OK soft key. You will hear a confirmation tone.
4helpful
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Recording Outgoing Messages:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
2helpful
3answers
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
3answers
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
2helpful
2answers
How to set Ans/Fax receiving mode of SCX-4521F?
Try setting the receive mode to FAX/ANS. If you want the fax not to pickup before a phone call comes in, you should set the number of fax rings to a higher number, like "5" for instance. Set the answering machine rings less and the fax higher. The machine will usually record a message first and then detect a fax tone.
1helpful
Bang and olufsen BEOTALK 1200
Make sure answer machine function is turned on. Bottom right button.
Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
