A) GE 15069 image at Amazon
http://www.amazon.com/60-minute-Automatic-Shut-Off-Timer-Switch/dp/B002DNAE7Q
15069 manual
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/In-Wall-15069-Manual-eng.pdf
Manual shows GE 15069 countdown timer is rated up to 1/2 horsepower
Whole house fan is likely 3/4 horsepower >> check nameplate on fan motor.
B) work around:
Hook timer up to a contactor/relay.
Timer turns on 120 volt, 7 watt contactor coil.
Contactor turns on fan motor
http://waterheatertimer.org/H230A.html
Square D contactor at Grainger
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B132?Pid=search
http://www.pexsupply.com/Furnas-Controls-45EG20AF-2-Pole-30-Amp-120V-Contactor
I buy these contactors at local HVAC supply for $15
add a comment if you need help wiring this device.
C) List below shows countdown timers with horsepower rating:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Lutron MA-T51 countdown timer specifically says it cannot be used for motors, which says the electronics inside each device is Load specific
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
Check HP rating for timer vrs horsepower rating showing on fan motor label:http://waterheatertimer.org/Countdown-ti...
