Posted on Jul 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Constant paper jam on Canon PC735 copier. Tried all the usual steps to removing or preventing as paper jam, and they are not helping. The problem started after the cartridge was removed and rocked back and forth to get more ink life out of it. After it was replaced, the constant paper jams occurred. Even though the paper jam light is coming on, there is never any paper caught in the copier. It does not even feed.
Ben
Level 2:
  • Expert 108 Answers
  • Posted on Jul 20, 2017
Ben
Expert
Level 2:
Answers
108
Questions
0
Helped
89395
Points
277
If the machine did not show a paper jam until the toner cartridge was removed and then reinstalled, I would remove the cartridge and check the paper path for the paper switch, it normally is a small black lever. Make sure it isn't stuck in the down position. If the switch is OK, check the cartridge to be sure there isn't any damage that may cause the paper switch to be actuated when the cartridge is installed into the machine. Sometimes there is a protective cover on the cartridge that moves when installed, this cover can be knocked out of place.
5 Related Answers
Anonymous
  • 161 Answers
  • Posted on Oct 04, 2007
SOURCE: Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Anonymous
  • Posted on Apr 06, 2008
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Anonymous
  • 12 Answers
  • Posted on Oct 21, 2008
SOURCE: On a Canon MP 460
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Robert Kitaji
  • 1335 Answers
  • Posted on May 05, 2009
SOURCE: Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
Anonymous
  • 328 Answers
  • Posted on May 15, 2009
SOURCE: my Canon PC735 copier turns off after it grabs the paper.
Main lamp is most likely burned out or is shorting.
You can google it and find a replacement bulb. Not too difficult to replace. Remove the top cover and glass. Make sure your hands are very clean or use a clean cloth to handle the new bulb.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
How do you clean sensor on canon pc735
Find the sensor and make sure no paper particles are blocking it.
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
1helpful
2answers
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
2helpful
2answers
My Canon PC735 copier turns off after it grabs the paper.
1helpful
Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
2answers
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
5helpful
CANON PC735 COPIER, PAPER JAM LIGHT KEEPS COMING ON BUT THERE ISNT ANY PAPER OR ANYTHING BLOCKING THE MACHINE, TRIED RESETTING IT NOTHING WORKS PLEASE HELP.
For the problem with the personal copier pc735 paper jam, I had the same problem. I was told the problem might be fixed by downloading the drivers and reload them. The PC735 I have does not have drivers nor a scan. My problem was a spring fell off on the idler gear and had to be reattached. I then cleaned the interior and this fixed the copier. You might look to see if a spring came loose on the back side of the bottom frame. I'm no machanic so I had a canon rep fix it for me. This fixed my problem. No more paper jam light.
Bob At [email protected]
3helpful
3answers
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
4answers
Printer says it is jammed
unplug printer from wall for 12 secs and plug back in
old marine
old marine
ZJ Limited
ZJ Limited
