Changes to the contents stored in the address book do not become effective in the stored speed dial numbers in Windows®.
Description:If you have made a change to the contents stored in the address book, the speed-dial is NOT automatically updated.
If you change the address book entry, please follow the steps below to store the speed dial number again.
Notes:
You can also access the Brother PC-FAX Setup dialog box by clicking start => Programs => Brother => MFC-XXXX or MFC-XXXX LAN (where XXXX is your model name) => PC-FAX Sending => PC-FAX Setup.
If you put the patch below, the message that prompts you to confirm the destination number or address will appear when you send a fax using the speed dial. Also the message that indicates changes in the address book do not become effective in the stored speed dial numbers will appear when storing a speed dial.
Trust this is helpful. Please vote. :)
Brother and its logo are trademarks of Brother Industries, Ltd., Japan. All specifications are subject to change without notice. All registered trademarks referenced herein are the property of their respective companies.
