Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
IF YOU LOOK UNDER DRIVERS SEAT FROM BACK PASSENGER SEAT YOU'LL SEE THE CARS ECU IS MOUNTED THERE. THERE WILL BE A SMALL LITTLE "WINDOW"ON BACK EDGE THAT WHEN YOU TURN THE KEY INTO THE ON POSITION ANY TROUBLE CODES WILL CAUSE A RED LIGHT TO BLINK IS THIS WINDOW. THE SERIES OF FLASHES(LONG FLASH=10 SHORT=1) WHICH TRANSLATE INTO DTC . EXAMPLE TWO LONGS FOLLOWED BY 3 SHORTS ==DTC 23. IF THERE ARE MORE THAN ONE DTC STORED THERE WILL BE LONG PAUSE BETWEEN EACH SERIES OF FLASHES
To get it into pairing mode (flashing red and blue) turn the headset off. Hold the main button down until the light goes red and then off. Then push and hold that same button and keep holding it even after the blue light comes on. It will now go into pairing mode, flashing red and blue. Set your cell phone to find it and it should work.
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
yeha me 2 today a woke up to a red flashing light on my ps3. I wondered wut it meant, searched it on google
and found some pretty bad news. DEAD. after about 1/2 an hour of trying
to turn it on i search a fix on google, but came up empty handed.
i
decided that i would take the matter into my own hands. i took the hard
drive out and turned it on, and to my amazement it work i dont know
how, but it worked. i then wanted to play resistance fall of man. i
booted up the game and boom it turned off beeped 3 times and the light
flashed red onece again.
i
took out the hard disk and booted it up again turned it off and put the
hard disk back in. ive been playing ever since and it seems to be
working fine. just thought that id give u guys a heads up, to help
anyone else out there with the same problem. Hey, today a woke up to a red flashing light on my ps3. I wondered wut it meant, searched it on google
i
i
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
