This is usually an indication that either there is a problem with the power supply or there is a short circuiting. I would advise you not to play the receiver as this clicking noise could cause damage to other internal components. You need to open the receiver and check for the faulty wiring or circuitry. Make sure that the receiver is getting appropriate voltage.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your response!!
This cannot be the case, however could be coincidence.The
clicking generally means that the relay is trying to close but for some
reason cannot.Usually, (but not always) this indicates a problem in the
power supply such as a blown voltage regulator or a zener diode.However, as i mentioned that it would be tough to diagnose the exact fault. Onkyo receivers are quiet reliable, however this is a common cause on most of them.
Hope i helped you.
One thing that is interresting is that this started happening when Cox Communications did an upgrade in our neighborhood. Could the upgrade be confusing my reciever because this only happens when watching TV?
Thank you sir, I will have this looked into by a professional
