SOURCE: Cannot sight in riflescope for elevation, adjustment is maxed out
Try reversing the rings. Move the back one to the front, and the front one to the back. Turn your elevation adjustment, back to -0-, and start again.
SOURCE: scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
SOURCE: I have a 25 year old Redfield 6X18 scope, with an
bullet drop compensation,,,,compleat hog wash!
no such thing in a scope, only a realy pricy one like £1500.00p worth and there not that good! but there coming soon! driven by a lazer for range finding,,,
still your scope has clouded up becouse its leaking
water has got into it, it could be repaired but its not cheap to do, it needs a complet strip down all the class cleand and new seals then a re-gas and it should be as good as new for another 25 years or so,
any good scope with mill dot will work for you, you just need to relurn the bullet drop over again,,and with the years of shooting you have had that should come easy as falling over,,,why not just get a good prised 3/9x40 mill dot and try that out insted, you will be plesently pleased with todays mid priced range scopes treet your self, and save money at the same time
Testimonial: "Both Leupold & Nikon DO have bullet drop compensation reticles, which are similar in principal to the mil-dot. The BDC scopes are becoming very popul"
SOURCE: I'm using a red dot scope on a mossburg turkey gun
Your mossberg turkey gun is fine, 30 - 40 yards is more than plenty for turkey and other game, I'd dont see a point of adding a bigger and better red dot. I converted my mossberg 500 turkey gun into a defender with compstock, heat shield, surefire tac pump mount. sticking to slugs and hatton rounds for three purposes survival, breaching door hinges and, for defense
SOURCE: I run out of elevation when mounting a scope to my
this is not that uncommon when mounting a scope on a rifle, the way to get around it is easy
find yourself a strip of old camera film (35mm) cut a strip off and slip it under the eye end of your scope then nip up the top mount this will drop the point of aim in the scope, i use this every time i have this happen to the guys at my club but dont try to put more that say 3 strips of film under the scope or you wont get it to shoot down low,,,
