1. Press Menu/Set, 2, 3, 1.
2. Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3. Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter a pause in the dialing sequence (for example, to wait for an "outside line"), press Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing Redial/Pause enters a 3.5 second pause when the number is dialed.
4. Use the dial pad to then enter the name (up to 15 characters), and then press Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name, press Menu/Set.
5. Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or, if you haven't stored a name, the number you've stored.
If you loose electrical power, auto dial numbers in memory will not be lost.
(For USA Only) One-Touch key 1 has been pre-programmed for the Brother faxback system. One-Touch key 2 has been pre-programmed for the CallManage long distance plan. You can override them if you wish.
Note If you need to store a pause longer than 3.5 seconds, press Redial/Pause two or more times.
Note - You can store Groups (for Broadcasting) on the One Touch keys.
