You don't say what type of connection you are trying to use. This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software through the Firewire cable. Confusingly, Sony call Firewire "i.Link".
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
This solution is only applicable for the selected camcorder models. You can follow the steps mentioned below for the DCRHC36 models.
Only the USB driver included on the supplied CD-ROM will properly enable the camcorder for USB streaming. The USB Streaming Driver can only be installed from the supplied Software CD.
o NOTE: The computer must have compatible video capture software to complete this procedure. Many video editing software applications include a capture function. If you have video editing software, you might not need a separate video capture application.
Good Luck
FixYa
