Lands Phones Logo
Posted on Jun 29, 2008
Motorola E815 has been paired with VRBT300V Bluetooth
All has been well. Today when I went to pair the cell to bluetooth the cell screen just wont' go past "Seeking VRBT300V" screen. It just hangs there and won't connect.
Bluetooth is charged and cell is charged....
  • 1 more comment
  • Leesa Carter Jul 01, 2008
    Have a motorola e815 cell phone and the VRBT300V bluetooth speaker from Costco, too. I cannot pair it with the cell phone. This speaker pairs with my Blackberry, so I know it works. Followed the manual instructions on both cell phone and bluetooth speaker, and still could not get it to pair. Any suggestions?
  • apatters2000 Jul 01, 2008
    I have a LG VX8700 cellphone and recently got the VRBT300V at Costco. When I originally set it up to work with my cell phone yesterday it worked fine, paired up and synced just fine. However, today after both were powered down and then powered back up, my cell tells me that the VRBT300V is either out of range on not on, which are not true. I even deleted the VRBT300V from my phone and paired them back up again, which worked fine but it still will not correctly sync in bluetooth mode.
  • slohuevo Aug 03, 2008
    I have a motorola Q, and i can't paired with vrbt300v, how i can fixed that
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
753
Points
The answer is to press the multi-function button once to instruct the device to re-connect to a cell phone that has become un-paired.
Here's a link for the instruction manual: http://www.roadmasterusa.com/forums/index.php?act=attach&type=post&id=125
Anonymous
Level 1:
  • Posted on Nov 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
753
Points
November 2008 ... same problem with VRBT300V from Costco and Motorola Q9
with my Motorola Q9 I was able to do the initial sync ... and it worked fine ... send and receive calls "hands free", even voice dial ... which I haven't figured on on the Hand Held mode ....
but after shutting down they wouldn't talk to each other ... tried deleting the link on the Q9 and now it doesn't see the VRBT300V
A
Anonymous
To make it louder, just use the toggle switch above the on/off buttons. Toggle to the right to make it louder. I have found it to not be loud enough in certain situations were road noise is problematic.
A
Anonymous
Still need help...My phone syncs (bberry curve 8300) but the bluetooth symbol doesn't appear on the VRBT300, and the phone just keeps saying waiting for VRBT300V
Anonymous
Level 1:
  • Posted on Jul 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
753
Points
I recently bought a VRBT300V at Costco. I cannot seem to get any volume out of the speaker making it impossible to answer the phone or use im my automobile
A
Anonymous
Does anyone know how to make this unit LOUDER!
Anonymous
Level 1:
  • Posted on Jul 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
753
Points
0
I just bought this unit today at Costco.  I read a post on yahoo that said to make sure that you hold the on button long enough to see the blue and red lights flashing.  Once I did that my cell phone had no problems finding the unit.
How do I connect my Motorola H720 Bluetooth headset to my PAnTECH P7040 cell phone?
Sharon-
Turn on Bluetooth on your pantech phone. Then H720 Bond Pair .
Mark
Motorola Support
Motorola Owners Forum
need help pairing my H70 Motorola Bluetooth with my Pantech P7040 cell...
Hello i've been trying to send pics but they will not go threw i've tried with 3 different phones
To send pictures from your phone, ensure your phones bluetooth is tuned on, also the phone you are trying to send the picture to should have his bluetooth turned on.
If it requires pairing, pair the devices by sending a file to the phone then it requires you to pair up the devices. Enter the same passwords on both phones and it will be paired, then your pictures will go to through.
If it does not, then it means your bluetooths version is different from that which you are sending the pictures to.
Try to send the pictures to a similar kind of phone.
Take care.
14helpful
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
33helpful
3answers
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
4helpful
2answers
Help pairing my H12 bluetooth
I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
2answers
Bluetooth Problem w/ a Motokrzr k1
My VRBT300V has stopped working. Every time I try to get it to link up to my phone it keeps telling me ..."No device found" I have followed all the instructions. Up unitl recently it was working fine. It by the way is the 3rd one I've had Had to return it twice to Coscto..you think I would have learned by now.
JM
Motorola HS500 Headset
I had the bluetooth paired with my red motorola raza, I just brought the grey motorola raza and I cannot get the bluetooth to pair with my new phone. It's the same exact phone, just a different color. The bluetooth is fairly new. Now the bluetooth wont come on at all since I tried to pair it with the new phone.
Pairing to bluetooth
The V3C cant pair with other phones.. I have to hold my bluetooth head set on top of my phone to get it to pair sometimes and make sure the headset is in pairing mode
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
