Question about Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr
Our timer does not seem to be working right. I have lost the book. I want it to be on from 6-9 p.m. every night. Can you help?
Here are generic troubleshooting steps:
If plug-in timer doesn't work
a) Check receptacle for power
b) Check lamp is turned ON
c) Check bulb is good.
d) Mechanical timers: Check tabs or pins are set
e) Check override switch pushed fully in position
f) Try timer in different plug and with different lamp
g) Test circuit with inexpensive circuit analyzer from hardware
h) Don't exceed maximum wattage
i) Programmable: check for overlapping programs
j) Programmable: write out programming steps and double check. Reset timer.
k) Outdoor with photo cell > test with black tape over photo eye
l) Turn photo eye away from light source
Add a comment any time
Next step would be to identify exact timer, and check steps in manual.
You posted under Noma programmable 6 button timer:
Your timer may appear among timers on next page > each timer has link to manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Our timer does not seem to be working right. I - geno_3245_165.jpg 6 button 7-day
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
geno_3245_166.jpg Generic 6 button Week
Posted on Dec 10, 2010
6ya staff
SOURCE:
I want to set the timer to go out pm, and on am. I find the instructions very confusiing
http://waterheatertimer.org/How-to-set-timers.html
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 17, 2014 | Hardware & Accessories
Westinghouse outdoor timer with 6 outlets instruction manual
1) Copy following link to help identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) After viewing link above, add a comment with clear detail about timer
Dec 22, 2012 | Hardware & Accessories
Hey im having a problem, basically all im trying to do it make it so my heat lamp turns on only at night, so, i set my time to the correct time right now and then i pressed prg, set the days (everyday)...
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
http://waterheatertimer.org/pdf/Zilla-digital-manual.pdf
1) There is no repair for defective timer.
According to manual, under Initial Timer Operation: yellow outlet is ON at 4:00 pm.
Make sure Mode button is not set to OFF.
2) Scheduling timer: Think about the zilla timer this way:
Day is 12 hours and night is 12 hours.
Your total schedule is only 9 hours, but it overlaps day and night.
If timer 'night' starts at 6pm and ends at 6am, then your programming overlaps day and night.
If timer 'night' starts at 12midnight and ends at 12noon, then your programming still overlaps day and night.
3) To solve zilla time problem, set current time differently.
4) Or buy GE or Utilitec 24-hour programmable power strip
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 28, 2011 | RTO Zilla 24/7 Digital Timer Power Center
I have a Westinghouse 7-day Digital Timer model# 28442 and I can't seem to get it hooked up properly. I lost the instruction booklet and just can't get it to work. Can you help me?
Open following link to identify timer and download manual:
Westinghouse timers sometimes have more than one number, and it is unclear what the difference is.
If your timer does not show, add a comment with description of the timer for possible help.
Upvote the help.
Jun 02, 2011 | Hardware & Accessories
I have a noma outdoor mechanical 3-outlet lighting timer power stake with built-in photocell technology- 5 off settings but I lost the directions on how to set it. on the back it's marked SP-030 ...
the 2/4/6/8/ hrs settings work like the photo cell and start at dusk then remain on for the time set , ie 2/4/6/8 hrs then shut off
Dec 18, 2010 | Solar Home
LOST INSTRUCTIONS FO NOMA TIMER MODE ET420C
Page shows all ET series timer manuals.
Including ET420 and ET420C
ET420 appears to be a plug-in outdoor timer
http://waterheatertimer.org/UPM-timers-and-manuals.html
UPM website that posts these timers seems to be shut down.
Nov 23, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
..not able to set timer to come on and go off a certain time
the pin for the timer and be any color.
if you have the pin in the right place, and turn the timer dial to the time you plug into the wall and turn on the black switch on the side. it shoud work.
check the timer after couple of hours. and make sure the timer is running correctly.
chances are there is a flat spot on the timer. it stops at a certain spot.
hope that helps
Apr 09, 2009 | Intermatic & Lighted Dial Timer
Resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
Dec 08, 2008 | Coleman Cable Outdoor Easy Set Timer #4604
Message
dial voicemail
mailbox 0#
123456# (Depending on the voicemail and release)
9
3 for AA
1 (AA number)
1 day (2 for night)
6 to modify
when asked to enter selector code...JUST PRESS * #
record there
www.telemanuals.com
Dec 12, 2007 | Avaya Partner 34B Corded Phone
Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr Logo
306 people viewed this question
Top Solar Hardware & Accessories Experts
Sheldon Dedek
Gil Shultz
STEVE
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
