The actual error is JVM Error 517. It means the file system on your blackberry is corrupt.
To correct this, follow the steps outlined below:
1. If not already installed, download BlackBerry Device Software and BlackBerry Desktop Manager from the wireless service provider web site.
2. Install BlackBerry Desktop Manager and then install the BlackBerry Device Software.
3. Use Application Loader to reload the software on the BlackBerry device.
Good luck and thanks for using fixya!
SOURCE: Jum Error 517??
Hi,your phone is corrupted,need to reset or update with firmware.
Use this instruction to reset
There are three main types of Reset that apply to the Blackberry. These
are listed in order below. Instructions for Blackberry Pearl are
slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This
reset stops all applications that are running on the Blackberry and
will help if you are having problems connecting the device to computer.
This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This
takes you to another screen showing an hour glass. Allow the device to
reset. This helps if the device has suffered a more serious error. Be
aware you may loose some information from your device. A backup is
advised prior to proceeding if at all possible.
3) Hard Reset -
this is the full blown reset and will fully reset the device to help
resolve critical errors with software or hardware. Again back up
important information before proceeding if possible.
Note:
For RIM models 850, 857, 950, or 957, you must insert the end of a
paperclip or similar blunt object into a small recessed hole on the back
of the unit and depress the switch inside. The device will reboot and
be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl:
To reset to factory defaults enter 'Options' from the main menu. Scroll
to Security Options and press the trackball. Choose 'General Settings'.
Press
the left soft key, then scroll to "Wipe Handheld" with the trackball
and press the trackball. To initiate the factory reset, your phones
security code may be required in order for the process to complete. Your
phone will now be restored to its original settings on leaving the
factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be
aware that resets such as these may erase data, such as contacts, ring
tones, pictures, text messages and stored Internet files and emails.
Make sure to back up important information beforehand if at all
possible. You can obtain software to back up the device to your computer
directly from Blackberry right here.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
and after resetting if no response,then you will need to update with firmware.GO to blackberry web site for update .
