M-Audio FireWire 410 External Sound System Logo
Posted on Dec 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, i've an m-audio 410 fw and windows 7 64bit.the os doesn't open drivers-exe file that i've downloaded from m-audio web site.why? thanks
Vignesh Ramamoorthy
Level 2:
  • Expert 305 Answers
  • Posted on Dec 10, 2010
Vignesh Ramamoorthy
Expert
Level 2:
Answers
305
Questions
0
Helped
54773
Points
885
Hi Sir/Madam;
I have provided you the source link to download the M-Audio FireWire 410 driver.
Click Here to download: M -Audio
  • Just click the link below
  • Then choose you device from the list provided
  • Choose the operating system type for which you need the driver
  • Download the driver.
Thank you for using FixYa.
2answers
I want to download the driver for the Zorb mm-180
Windows 10 and legacy drivers:
https://carson.com/customer-support/software/
Windows 10 file name: xploview v3.3.31.rar
A .ZIP or .RAR file extraction program is needed if your OS does not natively open the file.
I have aproblem with my sound. I've just installed new OS windows xp black edition 32. bit, it's all OK but there is no sound just yellow mark with " Audio device on High definition audio" mo
Hello you can download the driver here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5GL-MX&p=1&s=22
By selecting windows xp, and open the Audio folder, and click global for download.
The audio file needs to be unziped, before you install the driver.
Reboot after the install is done.
Update the other drivers, if any missing.
The audio file is newer present, in the xp installation file.
Good luck
Hi I bought a Canon Canoscan FS4000US used online. No driver came with product. Canon website does not offer any downloads when viewing canon website with WIndows Vista 64 Bit. It does show available...
When I go to the Canon site, I get prompted to select my OS: http://usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_fs4000us#DriversAndSoftware . On other parts of the Canon support site, I need to click on a Change OS link to get that dropdown menu or swap to the Select OS in that dropdown menu and then refresh the page. Then I can select a new OS. (Note the site uses Javascripts that do not seem compatible with all browsers. I found it worked with Firefox 6.0.2 . The exact location is hidden until you agree to the Canon Terms of Use.)
However, this driver, fs4000usvst103ben.exe, is listed as a Vista 32-bit driver released in 2007. Since the 64-bit Windows requires signed drivers, Canon doesn't make 64-bit drivers for their older scanners. (This scanner was released with compatibility with Win98.) Thus you will probably get an error message about the unsigned driver when you try to install it.
If the driver refuses to install, you may be able to run the driver installer by using the compatibility mode. Download the file and save it to your hard drive. Right click on the exe file and choose Properties. In the Compatibility Tab, select Run this Program in the Compatibility Mode and choose XP. Click Apply and then OK. Right click again on the exe and choose Run as Administrator.
I hope this helps.
I need mp navigator but one that doesn't require winzip lol i can't figure out how winzip works
You can directly download it from the Canon Official Download site. Here's the link (click HERE), you'll need to select your Operating System (eg. Windows 7) by clicking the "Select OS" box (if it's a Windows O.S, selecting any O.S will work since it supports all Windows Operating System). Once your Operating System is selected, the available drivers and software for the selected Operating System will be displayed, click "Software" to expand it and again click the "MP Navigator Ver......." and then on the next page, click "Agree Begin Download" button to start downloading. It's a .exe file.
Regarding your Winzip, it's just a program (if you've installed it on your computer) which helps files to be compressed to reduce file size and of course it helps transferring multiple files as one file. Just consider it as a folder, you can drag out the files after it's opened and drop it to another folder of your computer or if it's a .exe file which is inside the Winzip, simple double-click it to run the program.
Hope this helps.
Good Luck.
Thanks for using FixYa.
2answers
Hello i've got an audio problem for my HP Compaq Presario V2000 Notebook, I want to download an audio driver after reformatting it but it seems that the drivers i've found on the internet...
Hi joriem739.
The link you provided is from the official site, so it means you can't find anywhere else on the internet a much better site to download the drivers you needed. Just make sure you choose the right driver. Are you using xp or windows 2000? There are 2 options there to download for windows xp, have you tried them both?
2answers
I can't connetc mx310 to my new computer. The computer is running windows vista. Do I need to download a seperate software ?
The printer drives varies with OS, even if the printer is of the same model. So goto canon website and specify your printer model and OS, download appropriate drivers and install it in Vista. Then you are good to go.
5helpful
3answers
Audio,video and chipset driver
my mother board intel d101ggc not suppot graphics driver pleas help me
Audio Driver file SP38615.exe downloaded from HP Compaq site after installation not working
HI
Try loading this drivers ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37981.exe
Thanks
1helpful
7answers
HP Compaq Presario C773TU with conexant HD Audio Driver for XP?
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
And then install Audio driver:
http://www.2shared.com/file/2944663/2a44c4df/sound.html
NOTE: The URL above will take you to a non HP Web site. HP does not control and is not responsible for information outside of the HP Web site.
Download Sound.zip file from 'Save file to your PC: click here' at right bottom of the website.
Extract the downloaded zip file to a folder on hard drive.
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse, Choose the location where you have saved the extracted folder.
8. Open the folder and choose the .inf file listed.
9. Ignore any errors you receive and proceed with the installation.
Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
The same method which is used for installing audio driver needs to be followed for modem.
Top M-Audio Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
