Does not read my DVD - will not play anything
I bought a '06 Dodge Caravan in '07 that had the Rosen Entertainment Center installed. There was no paperwork or remote control with this system. How do I find out if it is still under warranty and how do I find a local repairman. My zip code is 29745. My e-mail address is [email protected]
Thanks,
Lisa
SOURCE: dvd player hangs up while playing
Sir I dont think its the dvd that is not working I thisnk its the screen that is starting to fail, it can be that the dvd is not sending the video signal to the screen when you open it and thatt is why you only get the blue screen and nothing else, because if the dvd was not working let it be the laser or a motor the most common message that you get in the screen is no disc, but that is not your case so I would have the screen check on that portable dvd.
SOURCE: no power to Rosen DVD
Hello and Good day to you.
Please Follow this procedure for trouble shooting.
I hope this information will be helpful.Thank you and good luck.
Please do not forget to testify and rate me if this solution helps you..
