You didn't mention what brand powered mixer you have, HOWEVER MOST powered mixers also have a line level monitor and main output jacks. These are almost always 1/4 inch jacks. In any case you should be using BALANCED lines to the powered speakers using either XLR or TRS connectors on the ends. Please tell us what powered mixer you have so we can give you better answer regarding which connections to use. IF for some reason your mixer does NOT have line level outputs, you can use a high level Direct Box to condition the powered outputs to be sent to the powered speakers..
Also make sure ALL your interconnected equipment is powered by the same receptacle or source to avoid damaging due to ground bounce on utility lines and circuits. This often means running an extension cord from the stage where the powered speakers are along with a snake of the audio cables.
I did say what monitor "Purchased Kustom 10" powered monitor". The monitor is the same brand as the power amp. In the meantime, I looked at the PDF owner's manual and finally got the powered monitor to work. My question is who is right about what kind of cable should be going to the powered monitor from the monitor out of the power amp. One guy at Musician's friend said use a speaker cable, and one said use a shielded instrument cable. Who is right?
