Hi!
I am trying to locate relacement parts for this model(1740).
tape motor badly worm, the belts are Junk, we have 25 of these to service. Would like a parts breakdown with prices
The majority have wavy audio, and adjusting the trim pot on the
board must be turned up to get right speed.
Help!!!!!!!!!
thank you!
Patrick bozarth
southwest electronics
5629 east broadway
Spokane Washington
99212
509-536-9110
[email protected]
Hi, Does the tape move when you press rewind or fast forward. If the tape moves for a few seconds then bleeps it sound like a sensor problem. If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward. Hope this helps.
I have an older Montgomery Ward Snow Thrower model No. TM0-35286A and I'm having a hard time finding parts for it. The tiller just stopped working so I'm thinking the worm-gear is shot, but I can't even find the part on-line...Can you help?
The drawer on a dvd player is a rack and gear drive. Sounds like you may have a bad motor or a jammed drawer. If you take it a part, see if you can find the motor that drives the drawer. It should have a worm gear on it. Try to turn it to release the drawer. It maybe out of time or slipped a tooth on the gear, hope this helps
HI... There are 2 belts in the mechanism that would need replacing. I've fixed 2 of these. There's a very small belt on the underside of the tape drive assembly 1.55 inch belt x 0.039 www.studiosoundelectronics.com # SBO1.55 Dont remember the other
شما میتوانید با شرکت ترنج پرینتر در ایران با شمارهای 00983112683688 تماس بگیرید تا برای تعمیر و سرویس دستگاهتان یک نفر پرسنل تعمیرات بسیار مجرب در اسرع وقت به محل شما ارسال کنیم با تشکر ترنج پرینتر
Very close; stand mixer parts (included accessories and manual only) can be accessed from this page: http://www.wpcookware.com/categories.asp?cat=32 Just select your mixer's part number (located on a sticker inside the base) and click the link for a list of available parts. You will have to create an account to see anything useful, but all they ask for is your name, a password and an email address. When adding items to your shopping cart, be sure to check the 'Select Item' box. The ordering page will ask for the usual info. Prices are reasonable, but beware the shipping cost!
