If you're replacing the spark plugs in your car
engine, you'll need to set the gap before reseating the
spark plug. The gap is the distance electricity arcs between the ground
electrode and center electrode. The gap must be set correctly to ensure
maximum performance. Here's how to set the gap of a spark plug.
Good Luck
SOURCE: Need spark plug gap for 94 Mercury Sable 3.0L
Listed in the owner's manual and under the hood on a placard. Also the parts store where you buy the plugs can supply this info.
SOURCE: Spark plug gap on a 1992 Gmc Sonoma 4.3L V6 FI
Usually somewhere on the engine or in the engine compartment, there is a sticker with the engine specifications. The spark plug gap should be included. If not .032 or an inch should be close.
Good luck
SOURCE: i need spark plug gap for 92 onda civic
for the most part there is a label under the hood you can also call your local parts store and they tell you give these websites a try www.alldatadiy.com and www.autozone.com wish you the best of luck Michigan Man
