SOURCE: Paper Jam Error 2
Samsuing SCX 4200
would not give up [Paper jam 2 - Check Inside] alarm
no jam, nothing broken, turning off etc. no help
Finally put a sheet in halfway through the manual feed slot
- had door open doing it so I could make sure sheet went far enough so that the little two-pronged black flag right at front of the paper feed opening was kept pushed down by the sheet.
Then used Copy to copy the sheet - this got rid of the false alarm. Prints ok again.
SOURCE: Epson RX595 Phanton Paper Jam
Please open all the side flaps and close it. Then see the result
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
SOURCE: Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
SOURCE: HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
